I think it would be an advisory for sure but not a fail, until I read this, seems to be a decision made at the discretion of the tester. That said I'm sure there's an MOT tester on here who can answer that one. :thumbs:Can anyone tell me if the rear disc guards / cover / plate (cant remember what they called) are a MOT requirement .
I think it would be an advisory for sure but a fail until I read this, seems to be a decision made at the discretion of the tester. That said I'm sure there's an MOT tester on here who can answer that one. :thumbs:
Brake backing plate [Archive] - Volvo Owners Club Forum
I don't know how you would replace the anchor plate without removing the hub.They are so rusty they are easily cut off with disc removed. No need to remove hub all though I believe mirlock is changing bearings anyway. I've had 2 mots without but understand that some testers are more fickle than others.
I didn't replace it. I cut it off before it rusted to pieces. The remains of the plate are still attached. I won't be bothering to put new ones on as they are not required for mot.I don't know how you would replace the anchor plate without removing the hub.
The axel is going through the plate and the bolt are behind the hub
