me again
put a puller on the hub and pulled it off and its left the bottom part of bearing on the shaft, i looked underneath and i can see 2 holes , is there meant to be a special tool to bang / press the bearing off instead of pulling it
thanks
..... is there meant to be a special tool to bang / press the bearing off instead of pulling it
The bit left behind will be the rear half of the inner race, no special tool, you'll have to go at it (carefully so as not to score the stub axle) with an angle grinder.
Good luck
Pub
Good luck
Pub
Roger that , Thanks Pub :thumbup:
Use the grinder to cut a bit of a slot across the inner race. It should leave a bit of a raised 'side' to the cut. Then give it a sharp blow with a cold chisel on the side .. it will crack and that will be enough to let it free .. done that twice now ..
