1 - 9 of 9 Posts
I've got a very odd problem on a clients site ... basically I need to open an RDP session and when I disconnect I need to to remain logged in (I've got an SSIS script that I want to run overnight in BIDs), however after a couple of hours it (forcably) logs me out ...
The (virtual) machine is running Windows 2008 R2 Standard, it's part of a domain and I'm logged in as a domain user, although I have local admin rights on the server itself. The Domain GPO does not have any of the terminal services timeouts configured (confirmed by running gpresult /v) ... in addition I've tried setting the local GPO to have all the timeouts disabled.
The terminal services licences are licenced from a seperate terminal services licence server (I don't know if this has any effect)
So what else can I try to make myself not timeout???
Ensure that the session doesn't become inactive? Run a WinMTR trace route or similar that will use only modest resources but keep on running until you stop it.
If all else fails I'll give this a go ... just want to do it properly (it's taken my 6 weeks to get the paperwork approved to allow me to do this!!!)
Configure Timeout and Reconnection Settings for Remote Desktop Services Sessions
Might help
Alternatively use a stored procedure to fire the ssis package withparameters if needed on a timer
Those settings appeared to be grey'd out (even though I'm a local admin) so looks like the licensing server is taking control of the settings (which I don't have access to) ... at the bottom of the page lists the group policy changes that apparently do the same thing and those are the values that I changed.
I'll contact the guy who administers the licensing server on monday ...
It is an odd one, licensing server doesn't control this, are there any more GPOs on the server?
I tend to make specific GPOs for a single setting or a subset of settings. This makes it easier to dig down to where the problem setting may reside.
Also run rsop.msc to see what settings are applied to your session, this would be a good starting point.
gpresult would also tell you if the policy is correctly being distributed to the machine.
Hadn't heard of rsop.msc before ... it's fantastic ... I've found the GPO that is enabling the timeout (it's a computer configuration rather than user), it's odd how the local policy hasn't overridden the setting though :confused: ... do you know if it's possible (at a local level) to enforce the order that GPOs are applied? or am I going to have to go back to the domain admins?
You can't set precedence, all you can do is perform a gpupdate at the machine, some user policies require a logoff, some machine policies require a reboot.
You can run gpupdate /force to perform a background refresh of policy and it will ask you to logoff or reboot where applicable.
You can also create a html document detailing the applied policy, look up the usage for gpresult.
Not that that will help your current situation.
Resultant Set Of Policy (rsop) is first place to look when things arent working as you expect :)
Done!!! although I did have to physically stand behind the domain admin and tell him what buttons to press (just after I'd received the obligatory sigh and ... "am I actually having to do some work").
Thanks GD for your help :)
You're very welcome :)
1 - 9 of 9 Posts
