noise came from gearbox cables, dismount left cover from center dashboard and pull carped down.
what do you need? it rattled at 3050 rpm , annoying as fk, kept them in a pulled position with some plastic holdings so that the metal wire inside the cable housing would not move as much hitting the housing thus making a rattle noise, almost fixed most of the sound, should change the cables.Any more details on this?
Have a similar noise, but not constant. Removed glovebox and everything around, behind it, as that's where the sound comes but it didn't stop. Also remove the wiper plastics and wipers and run it around (while the rest where off) and I still got the rattle. Mostly it's when the road is anomalous or over humps.what do you need? it rattled at 3050 rpm , annoying as fk, kept them in a pulled position with some plastic holdings so that the metal wire inside the cable housing would not move as much hitting the housing thus making a rattle noise, almost fixed most of the sound, should change the cables.
You've definitely got the same noise as me, same place, same type of noise. I read somewhere that someone had their dash out do it was a loose airbag mount that was making the occasional knocking.Have a similar noise, but not constant. Removed glovebox and everything around, behind it, as that's where the sound comes but it didn't stop. Also remove the wiper plastics and wipers and run it around (while the rest where off) and I still got the rattle. Mostly it's when the road is anomalous or over humps..
Went and installed a nice stereo and speakers for this, but occasionally it drives me crazy.You've definitely got the same noise as me, same place, same type of noise. I read somewhere that someone had their dash out do it was a loose airbag mount that was making the occasional knocking.
I've pretty much given up on it and started just playing the stereo fairly loud when driving around town.
Did you have a look at the underbonnet expansion bottle? Think I'll wedge this up next and go for a drive.I took the glovebox out and had a good rummage around (with battery off just in case intouchban airbag cable). Could feel anything loose.
I sit in the car on the left side, this is the driver s side, look at the center console and take apart the its left cover, the one you don t need tools, just pull it, then you have to put he side carped down, the carpet that sits vertically (Up), the gearbox cables are near your right side of your right leg, basically you have to get under de navigation, and in front of the gear knob. before putting the carpet down , or pulling it you have to dismount its 2 fixings. It s very simple 1 min to get to the cables, i didn t change them a put some fixings keeping them in tension so the metal cable inside them won t hit their protections. the area is kind of soundproff and the sound heard it came from the dashboard and then under it. first time i heard them only when the car was moving, but then it became obvious when the car was stationary at 3050 rpm 3100-ish. you have to accelerate the car at a certain rpm and hold the cables with your hand and pull them and see if the sound stops. I ve been searching for this sound for like 2 yers. Sry for bad english. Look i found a pictureDo you mean the coolant bottle OE? I've been right through the engine bay a few times, everything is secure. I've had the windscreen cowling off a few times too, retaped and mastiked all the windscreen clips, put new fir tree fixings in and checked for any loose fixings. nada. The last thing I can personally do is take the centre console out, but I doubt I'll be able to get my as far as the bulkhead.
