Rattle , Rattle , Rattle
1105 6
With this hot weather and the windows being down , i have a rattle on the the drivers front wheel area , if iam going round a left hand turn , hard there is a rattle on the right side , spounds like a symbol vibrating , once you are round the corner and straighten up it disappears , any ideas !:confused:
:thumbs: i don't know why it happens but i was unsure and took it to a dealership and they said they bent it back a bit and the noise stopped :) was quite handy for me because they also found a sticky caliper so stripped it out ad cleaned that all up too :)
I have this exact same problem - do you need to bend the shield back all around the wheel? and how far, I gave the top part a push back and it bent back further (and easier) than I expected...
It is also still in warranty - but if its a simple fix like this I`ll do it myself....
Rattle rattle
Hi folks I had a similar noise, every time I went over some bumps in the road at slow speeds I could hear a rattle coming from the front wheel area, just taken the car for a service and mot, mentioned the rattle, found it to be a broken front coil spring! Seemingly not safe to drive, so they have given me a courtsey car till parts arrive, so best check its not the problem I had.
