1 - 11 of 11 Posts
I do not know whether I should write this here.
I have a GTV6 2.5 with air conditioning, which the rats have eaten many of the motor cables. Among them, several of which are located next to the wiper motor. and some of which are located between the headlights and wiper tank.
Is there a way to get these cables or wiring diagram to tell me the colors of each wire and the part to which they connect?
I also like to know how to change the timing belt, and I can not find the points with which to align the camshafts.
Thank you all for your help and sorry if my English is not understood.
Seems you have a good little project on the go there !
Sorry I can't help with any specific advice.
Dear fellow forum:
As you know, my ***** gtv6 has a dual clutch gearbox, with the common problem that the first disc, closest to the pressure plate, touches far more than the second.
Such has been this erosion, which once spent all asbestos, has spent a metallic circle, and the plates that hold the brake lining on the inner side of the disc have been cut.
So I'm looking for the first clutch disc of this system (with reference sachs 1861.607.401) or a disc with similar plates to repair the mine (disc is 190mm in diameter, the plates are 0'7mm and club has a 20mm diameter, 20mm long and 19 teeth).
If the clutch disk 75, despite being a top diameter, must be of similar plates, I also would be worth.
Land Rover Dealership - true story
Service manager to tech: 'Have a look at that Defender 90, customer complaining of electrical faults'
Two minutes later, tech to service manager: 'A rat has been gnawing the wiring - needs a new loom'
Service manager: 'How can you reach that diagnosis in just 2 minutes'
Tech: 'I opened the glovebox and a rat jumped out'
1 - 11 of 11 Posts
