Quick question: I want to raise the rear ride height of my GTV by around 15mm and stiffen the spring up because my rear wheels are toeing in a bit much for my liking. Tire wear has been very good with 100% even wear over the entire surface, but this is because the toe has been compensated for by other means such as camber correction, etc.
My reason for dong this is because my rear wheels are scraping somewhere in the wheel well, towards the rear, as toe-in increases through dips and bumps. Toe is essential for stability but I could really do with less scraping now.
My question now:
What will the effect on handling be if I were to do this? It currently handles like a dream, to the point where I can add 20km/h on top of the 159's already generous corner entry speed and still floor the throttle all the way around the corner. I love that go-kart handling trick.
I aim to stiffen and raise by using "spring stiffening rubbers" as in: http://www.campingandcaravanningclu...AyADAAOAA2ADgAfAB8AEYAYQBsAHMAZQB8AHwAMAB8AA2
My question now:
