916 spider has developed a problem in that the radio turns itself on all by itself when you are driving and car and even when the car is parked with nobody in it
Is this a common problem and what is the cure ?
can't see how if the radio is on a switched live how it would do that...?
question 2 and 3
phase one or two car
and is the radio aftermarket, if so which make..
have fitted 3 radio's in the last few weeks to 916's and the wiring was slightly diferent on all..
edit
can you remove the radio and take a pic of the connections..
This sounds very similar to a common problem with the Blaupunkt radios fitted to 156s. The solution on the 156 is to keep a CD inserted in the drive at all times*. My son's 156 has a CD in it that came free with a newspaper - they can be found in charity shops. It's been in there years and has completely solved the problem.
May be worth a go ( or a cassette if you don't have a CD player ).
* I do recall reading in the 156 forum that this fix didn't work for one person.
