Just bought a GTV and the radio does not work. Just displays ---- on screen, I have dug out a code from previous paperwork, but nothing happens when I enter it. Tried with engine on and off!
Any advice ??
Hi, have you pressed the BND button to get 'CODE IN' on the display? Then you can enter the code and everything should be fine?
A
Dont you have to hold the button down for a few seconds untill it clears the dashes?
If none of the above suggestions work, you could contact Alfa with the reg number they will ask you for a copy of the reg document, and then they will get you the code (this is ok if it has never been replaced at any point) it cost about £20.00. It's worth a try if you want to keep the original radio in the car.
