Radweld.......:depressed:Cheers will replace then. Not leaking since I stuck a can of radweld in there but no doubt will start again soon. Other things to fix first!![]()
Well it's not leaking and the temp gauge is spot on so I don't see a reason to swap it yet.Radweld.......:depressed:
They are usually well past it long before they actually leak.
Radweld is a temporary "get you home" fix.Well it's not leaking and the temp gauge is spot on so I don't see a reason to swap it yet.
Isn't rad weld a bit of a no no? Risks blocking up water channels in the engine? Atherosclerosis for your car?!Radweld is a temporary "get you home" fix.
It isn't a permanent repair solution for a rad that is clearly failing.
I wouldn't put it is there.Isn't rad weld a bit of a no no? Risks blocking up water channels in the engine? Atherosclerosis for your car?!
SeeI wonder what his "other things to fix first" are.
