Hey Guys!
I had my GTV in the shop there recently and the mechanic noticed a slight radiator leak. I had noticed myself tiny amounts of water/antifreeze on the ground under the car over the last while. I was also loosing small amounts of water from the engine so that was another reason I was concerned.
I bought Holtz Radweld liquid to try and seal the radiator leak, question is: where do I put the liquid? Is it in the water container in the engine? The instructions on the Holtz bottle tell me to put it directly into the radiator but the GTV's dont seems to have a cap on the radiator or any access to it!
What do you recon I should do?
Cheers Rob.
Someone also suggested sticking an egg in it... but I recon he was taking the mick!:lol:
The much better product is something called " K Seal, " available on eBay. Used it almost three years ago as I had a very small leak from the Radiator, been leak free ever since. Of course if you have a relatively large leak nothing will work. Whatever you do forget the egg idea, used to be a dodge to try and get you going back in the good 'ole days !
The easiest way to use anything like this is to remove a pint or so of coolant from the header tank, sure you can figure out ways to do this, ( Coolant tastes 'orrible for instance ! ) then mix up some coolant to the correct strength with the K Seal in this. Add to the Header tank and let the engine run for a while ensuring that the engine is up to normal temp, 'stat opens, fans start up and that the coolant is circulating around the system. I did mine this way.
Another way is to remove the top hose at the engine side, this will enable you to pour the K Seal directly into the Radiator through the pipe. Of course this is a bit more messy and you will lose more coolant but is probably the better way. Same suggestions about running the engine as above.
Hope it works for you.
put it in the radiator expansion tank bottle, it's on the passenger side, smallest bottle near the engine,
but you will need to replace the radiator, it will seal it for now, but it's not a long term fix, i wouldnt relay on it,
new radiator is inevitable (around £200, plus labour unless you can do it yourself)
i've got to replace both of mine, air con rad and main rad so i am looking at approx £400,
good luck, hope this helps
