1 - 11 of 11 Posts
Hi all,
The radiator bleed screw is leaking on my 1.6.
Is there a way to fix this?
Does the bleed screw come all the way out? If so, would PTFE tape work?
Ideally need this fixed today as I need the car for work for the rest of the week.
Cheers all.
The bleed screw on the drivers side of the car does come all the way out.
You could try another rubber/nitrile washer on it. As a long term repair. I reckon ptfe would hold for now tho.
I've read the threads can strip on these things when you try and unscrew them which might explain why it was bodged before. Having said that it's not clear if this problem applies to the Rad screw or the others in the pipework. Need to bleed the radiator on mine really after changing the water pump but am a bit loathed to touch this thing in case it breaks.
I guess I'll take the bleed screw out, see if I can get a replacement washer from B&Q or something.
Do you know if its a washer or an o-ring?
yep. replace the o ring
Turns out theres actually 2 rubber o-rings on the plug, both about 19-20mm diameter. Ill replace them both and hopefully it will solve the issue.
:confused: mine only has one?
Are these screws prone to breaking or is that related to the other bleed screws ?
I've read a lot about them breaking, they seem pretty strong though.
The only complaint I have is the seals are rubbish.
There is an o-ring at the top, mine had a second rubber seal a bit further down the shaft of the screw.
Maybe technically not an o-ring but I replaced it with one as it was knackered too.
Done a few runs today and it doesn't seem to have leaked yet.
-touch wood-
S
Mine has a rubber washer just under the head of the plastic bleed screw. No O rings. Guess it varies by manufacturer.
All in all, I think I've never had more than the tiniest hoss of air out of mine when bleeding it.
On my last 156 - A 2 litre TS, it had no bleed screw (aftermarket rad) never seemed to be an issue.
1 - 11 of 11 Posts
