1 - 20 of 47 Posts
Hi fellow Alfa drivers,
I bought a 159 Ti 1.9 diesel in september 2011. The tyres on the car are ContiSport Contact 3's
I need to replace these soon but am looking for something quiter. these tyres currently 3mm from and 2mm rear are extremely noisy on course surfaces like the A1. I don't fancy paying out £235/tyre for the same, I don't through the car around a lot and have read some posts mentioning NANKANG AS1 96Y becuase of the assymetric pattern. since i'm on 19" Ti rims, the choice is limited. I assume all the blocky pattern tyres are noisy like the conti's? What are the Nankangs like as a tyre generally and are they quiter?
any opinions would be appreciated.
Loving my alfa 159 by the way. :)
Bignige
Bignige
I have just put on 4 Nankang AS-1's on my 2.4 Ti. I was staggered by how much quieter and how good they are for the money. I came from Pirreli's then bridgestones and i would say the Nankangs are without doubt as good as both of them. (havent had a chance to FULLY try them in the dry yet, but excellent in the wet) Just a shame about the silly name :tut:
I can say with confidence you'd not feel hard done by if you put 4 on :thumbs:
Linky of where i got mine, very good price & next day delivery via Yodel Tyre Traders | NANKANG 235/40R19 96Y AS1
Worn tyres, regardless of brand, can be noisy. I strongly suspect that a new set of Conti CSC3's would be significantly quieter than the currently worn ones.
But granted, if there's better value out there, consider it.
Never noticed any road noise with the Accelera Phi's on mine. I'd be interested to hear why cj romeo's doubts the Accelera's quality. I have no issues.
James
They grip well, and break away progressively, but there are a few stories about sidewall failure and them being easily damaged.
I still recommend them at under 100 bucks a corner though, for me just the last 5% of damp grip isn't there, whereas it is on the P Zero, though a P zero makes zero progress on compacted snow, the Accelera beats it there and is quieter, just watch the sidewalls for bulging and damage.
I did 52000 miles on lots of P zeroes and 3000 on the Accelera before I sold the car.
Thanks for your input guys....sorry to inflict another tyre thread on the forum but hopefully it will be usefull for others. :)
The utterly stupidly named Nangkangs, or is it Nankangs, are actually pretty decent.
I bought the 159 LE (same wheels as the Ti) with 4 of them on, thought I would have to ditch them straight away, but are good so far. Wet weather, dry, snow and ice.
James
I've just brought Acellera PH1's for my ti and would agree with James on how quiet they are.
Got mine from Camskills at £80 ish a corner.:)
Before this starts being "common knowledge", because I heard it on the interwebz. The only case I've seen of this was in a thread on here, where the wrong size and load index tyre had been fitted. If there are any other cases out there I will quite happily stand corrected though.
Other than that I agree with everything CJ romeo said. Accelrea PHI's are OK, not great but surprisingly acceptable as long as you don't drive spiritedly/like an idiot in damp conditions.
I suspect the Nankangs will perform similarly due simply to the weight of the 159.
And as others have said any new tyre will give less noise than worn ones.
I was going to recommend Goodyear EfficientGrip but I couldn't find them in your size. I had them last two seasons on my ex-car and those are the quietest I drove ever.
I was told this by the (indpendent) tyre fitter who put mine on, I use him a lot and just told me to keep an eye on the sidewalls after potholes or kerbing as they arent as resilient as the premium brands.
Tyres with a low treadwear rating, as you would expect make less noise as there is less friction with the road surface (hence less grip too). I believe the Acceleras and the Nankangs both have fairly low treadwear ratings
Not necessarily. Noise & wear depend on many factors. Tread design has a big influence on noise, while more advanced compounds can combine good grip & long life.
It could be argued that tyres which achieve long life by using harder tread compounds will be noisier as the hard rubber doesn't absorb as much noise as a softer compound would!
1 - 20 of 47 Posts
