The problem is that when i turn on my 155 and also turn on the a/c the fan does not turn on,, in fact the fan only turns on after certain temp. the question is if its normal only to turn on at a certain temp. or should it turn on as soon as i turn on the a/c
I had a similar problem but I had breakdown with electric, and about your question, you must be specific, do you have a some king of timer for regulation of temperature (for example - fan is turning on 20 C) or you have classic regular cold-warm ?
thnx for the answer, about the fan,, it turns on after it passes 90 always,, and normally on other cars when you turn on the a/c the fan turns on,, but not with my car and it would like to know if its normal
On my 1996 155 1.8 TS 16V, the fan does not turn on automatically when I turn on the A/C. It's triggered solely by the coolant's temperature; when that goes over 90, the fan wakes up.
You'll note that usually running the A/C cold does warm up the engine quite a bit; I cannot run it while driving up a steep mountain road on a very hot summer day (over 30 degrees celsius).
pierre_samanni thanks for the info,, the reason i was asking is because the car is in the shop and the mechanic is asking if its normal or should he fix it.
