Hi everyone;
Currently my issue with the wiper is: The wiper works for like 2 minutes, then stops & doesn't work for 10 minutes. Works again for a while , then stops again
In this context , would only buying the motor part would be enough? I wouldn't be needing the linkage part , am i correct?
Best regards!
There is also a control box under the dash that can cause problems.
Have an update on a rainy day.
The wipers work for 10-15 minutes with 30 second non working times, however it stops fully working around after 15 minutes.
Driving the car with the visibility of a Van Gogh painting sure is something i want to avoid!
The printed circuit in the control box is your problem. Remove the mechanism, gently prise open the black plastic box, you'll probably find one or two sections of the circuit board need to be soldered (dry joint) and then lightly re-grease. It's not too bad of a job, otherwise buy another mechanism.
