I've plugged in my Blaupunkt aux-in cable, but as is common I've found no option to enable the aux-in and the SRC button isn't changing to CHANGER. It does occasionally when I push SRC on startup, but very rarely,.
Which of the terminals on the AUX-in plug do I join? I read somewhere '13&14' but which are these? What are they labeled as?
Discussion Starter #2
While I'm at it, does anyone know if there's a wire behind the stereo that's 12V only with the ignition? I can't seem to find one with trial & error. (Don't have my circuit testers to hand either!)
If there's not one I'll run a spur from the cigarette lighter power.
I've got a nifty little Harman Kardon Ipod kit to show off when it's finished!
I'll answer my own question here in case anyone else needs to know-
There's no ignition-on wire I can find, I piggy-backed a wire from the plug that goes into the cigarette lighter (The middle one on the plug)
N
I think all of the wires to the stereo
are always-on. :rolleyes:
Chasing one from the fag lighter is probably
the easiest. ;)
One of the wires is igntion related.
13/14 are on the blue plug, but depending on the head units firmware, it may not work, it doesnt work on our 147 (or 159)
