N
is it easy to adjust the clutch on the 155 2.0 TS 8V??? It feels too soft when i press down the pedal.
Thanks for a quick response
You don`t describe 'soft' in much detail but try to diagnose the clutch in the same way you would brakes as the clutch is hydrolic (pardon spelling).
Probably the easiest start would be to bleed and flush the clutch systemThis assumes that the whole clutch isn`t wearing out and the pressure plate needs changing.
N
Hi
thanks for the response. i had a panick attack yetserday, and thought my clutch was bad. took it to the mec today,and they laught at me..there is nothing wrong with the clutch they said, you (I) just got used to it, and therefore you dont feel it as ¨heavy¨ to press as before..
Thankx again.
O
Hi Nicholas,
155 8v clutches get HEAVY when they are worn. Anew one is light!!
Oliver
