Hello!
Last week I bought 146 1,6 Boxer. I suppose that my thermostat need replacement, because the engine is geting no warm enough. So I would like ask you if somebody know how the frigorific fluid can be let out of the frigorific system, because I suppose that when I want replace the thermostat there mut be the fluid by let out.
Thank you. (Sorry for my english)
Hi Patrik and welcome to AO :)
Its probably best if you post this question in the technical lounge as the right person is more likely to see it there :) Good luck :)
I'm thinking back a long way now, but I think there are two drain plugs on the engine block, one each side.
Removing the bottom hose from the radiator would be enough too, but better if you can fully drain the engine block so you add all new coolant.
Thank you very much David for your ansver and advice.
Patrik
