1 - 20 of 29 Posts
If the Giulietta uses a kkk03, Should you not be able to mod a Golg GTI DP to fit?
Regional Representative, For South Africa - AO-SA
Paul, what happened to Hygrade ?...
No idea about the Turbo, sorry
Jeeeeeeeewhizzzz, I can't believe you were thinking the SAME thing I was thinking after the DP discussion on the "other" forum!
I say take to FRC or whoever sells DP's...there's alot of Flowtech DP's doing the rounds that are aparently very good...and have them take off the GQV DP and try and fit the GTi/A3 K03 DP...but isnt the turbo's mounted differently? But that's not biggie...as long as you have the paceplate mated to the turbo, the size etc in 76mm you can get your guy at Dutch to bend a 76mm nicely!
First problem is that the VAG turbo sit behind the motor and the Alfa’s sit in front of the motor like a proper car’s should.
The flange could possibly be the same.
haha to answer the q.. NO the gti is a bolt on DP where the giulietta is a clamp
Was again thinking the same thing...don't worry, as soon as I take the plunge I'll explore aalllllll these probabilities!!!
I'm sure it must!!!
imagine..a k04 turbo, CPi map, S3 sized cooler, an oil cooler for good measure, modified ITG intake, water meth injection, K04 DP and full catback exhaust....OMG! That's 300BHP+ easy!
actually never checked if the QV has a oil cooler. I believe the ST has a similar DP
Similar to what? GQV?
Let them build it...someone pls borrow Slave Paul a car for 3 days so that much need development can be done to the GQV in SA!
Ohk..so the clamp goes around that clamp mouth..nice, it must be a heavy duty clamp then!
Its shocking how when you look at different manufacturers' aftermarket parts, you somehow see the resemblance in your manufacturer...how much you want to bet me that Alfa's share more than a Turbo from Borg Wagner with a VW?
Discussion Starter #16
hectic clamp... lol tension springs and all
That Rgazon Dp...what is the diameter of the turbo outlet into the DP? And what is the diameter of the DP into the exhaust? It looks very small...maybe some more horses to be released by just upgrading to a 76mm straight through with some boxes at the back?
This car has a lot of potential...someone (Mater Paul) must just unlock it!
1 - 20 of 29 Posts
