1 - 14 of 14 Posts
F
Hey.. the boredom is setting in.. can anyone explain how the Q4 active suspension works?
Cheers,
A
W
Discussion Starter #2
It moves therefore it works :confused: Thats all I need to know!
wrinx (sorry!)
F
ohh if it was that simple.
I think it works, but frankly it seems to be a rattle button. ie, you have rattles as you are driving along, press it & you get more rattles! :(
Never mind. I'm less bored.. which is good.
A
W
At least you have a button that will then reduce some of the rattles!! Sorry, I'm not being much help at all :eek: :rolleyes:
wrinx
J
i can tell you that new dampers are £380 +vat EACH.!!!!!there is a control unit in the car that adjusts the dampers via a switch on the side of each damper it operates a valve inside the damper to stiffen or soften it.
F
so is it all 4 dampers which adjust or just the rear two?
I wonder why they fitted it.. it really does appear to do nothing for your handling wink
J
its all four.!!! ive never noticed the difference on the lancias either.
So... what would you suggest: the Q4 controlled damping kit, or a nice Koni´s + Eibach´s springs?
I am asking this ´cause my Q4 is supposed to have the controlled damping kit, everything is installed, except for the dampers!!! I am now thinking about changing them, therefore I´d like to know your expert opinion...
Regards!
People who knows this with dampers says electrically controlled dampers never come close to manually adjusted dampers in terms of adjustment range. At least not the kind of dampers taht are fitted to the Q4. Go for the Konis!
/A
F
yep, the konis are fab,
get them
alan
keep her clean :D
9
Get the koni and eibach set-up, is a bit hard but great for road and track days Oh, and about half the price of alfa OE
Excellent!!! Just about what I was thinking!!! Jaja!!!
OK guys, thank you all for your opinions. I´ll let you know as soon as I get the Koni´s and Eibach´s... Just need Santa to be generous this year!! Jaja!! wink
Cheers!
1 - 14 of 14 Posts
