·can you explain how you fixed your variator? cut spring or make it harder or softer or else???? please help me i have problem with gangarooing under 3000 rpm
The best plugs to use are the Golden Lodge (original plugs). They are cheap (about £20 for 8) and they have 4 electrodes. My car runs much better with them in.9pui said:kangarooing,it happens when i travel at constant low speed (in traffic under 3k rpm) i have checked airflow,tps,lamda,etc.,any hole as seen on workshop manual.but everything's fine. i split lead and check it in the dark, it's fine. i use bosch F7LDCR,is it OK?
Try a new relay9pui said:To everybody,who has similar problem!!!!!!
today,i clean and check variator relay(nearby 3A fuse) again.
i don't know what i am thinking,till i unplug variator relay. get in car and drive..........................wow no kangaroo,now...
then i park and put relay back.
Oh no,kangarooing come back again.
now i unplug variator relay out.
i am very happyalthought timing variator does NOT work..
At least, i can drive mine as smooth as it should be
however, i still wanna put relay back for full system without kangarooing, somebody know cause????? please help me
