hi put wrong oil in selespeed bottle used gearbox oil should have put in cs oil will it matter put in about half a cup full shall i drain the system or will it be ok thanks
Depending how big you "cup" is, it is quite a lot. The entire system only holds 0.6L
As above, it needs flushing through with the correct fluid.
When the system is relaxed, most of the fluid is in the reservoir.
