Ah, I thought all doors were the same, cheers.It would probably be a good idea to specify which car you are talking about, as there may be differences between the phases and the GTV and Spider.
You can't really put a phase 1 door on a later car ( door check strap ). Other than that you should be OK.Ah, I thought all doors were the same, cheers.
It's for a Phase 2 1999 CF2 V6.
So that's a GTV not a Spider then?Ah, I thought all doors were the same, cheers.It would probably be a good idea to specify which car you are talking about, as there may be differences between the phases and the GTV and Spider.
PKR I am intrigued. I used a phase 2 check strap on my phase 1 Spider by enlarging the hole it fits through in the door. I read your cruise control piece by the way. Blimey O'Reilly that was a project and a half. Respect.You can't really put a phase 1 door on a later car ( door check strap ). Other than that you should be OK.
Exactly. It can be done, but metal work needed.PKR I am intrigued. I used a phase 2 check strap on my phase 1 Spider by enlarging the hole it fits through in the door. I read your cruise control piece by the way. Blimey O'Reilly that was a project and a half. Respect.
Is it beyond paintless dent removal?Yep a phase 2 GTV. Might be struggling to find one but don't really want to cover the current door in filler.
Thanks for clarifying folks.
