hi,
my 155 projector lense wont lite up on the passenger side...... is there anything i could do to repair the projector lense or its beyond repair... i have checked the fuse in the box beneath the driver dasboard but could not find the broken fuse.. every fuse looks ok... so is there any connectors/fuse that i miss out? is there away of repair the headlite or i have to get a new unit...
cheers
Re: projector lense
terpenland
i guess i read it wrongly... mine is 155.... and the front projector headlight not working not the rear brake light.. i dun think there's something to do with comp.box
Re: projector lense
Nahar, I think you're right, I was in a bit of a cynical mood. I hope there is someone in this community who can give you some proper advise. Good luck and I hope you can fix the problem in a better (read: cheaper) way.
W
Do you have power at the light and have you checked all the wiring? Check the bulb is ok and seated properly.
wrinx
