1 - 20 of 31 Posts
Hello i have one alfa romeo 156 1,9 jtd 16v E3 140cv, these are the photos of the project of coupling turbo of an alfa 159 210cv gtb2056v
Discussion Starter #9 (Edited)
First logs of the project with 90mm3, after having done 12 tests to ensure that it did not have very high pressure peaks with the amount of diesel of 80 mm3, after that increase iq up to 90mm3
I am afraid that the advance is excessive,
afr I have put on 14.7 from 1900 to 5000 rpm.
I think my flowmeter is in poor condition
regards
return to 80 mm3 , I return to the previous file with 80mm3 until well calculated SOI and adequate duration, the exhaust temperature rose a lot, the water also notice that it rose more, with 80mm3 the maximum exhaust temperature I have had so is 810 degrees (the probe is in egr cover)
JTD 8v Stage1+
SOI already is high in JTD 16v Euro3 vs others JTD (even JTD 8v Euro 2) due to "slow" injectors and Unijet pump.
810ºC with your injection duration is not bad, anyway duration looks like sligtly high. +17 AFR on high revs looks like ok.
rpm mm³/i ms deg. mm³/i mg/i °C mBar MBAR % VNT RAIL bar EOI?¿ AFR
1611 47,83 1,132 5,18 44,84 721,6 34,6 1482 2071 75 953,8 -5,762 18,06
1717 63,63 1,028 7,05 60,23 959,9 35,2 1920 2262 75 1019,7 -3,540 18,06
1800 71,4 1,102 7,92 69,17 1199,3 35,9 2445 2396 60,7 1118,6 -3.982 20,11
2180 78,67 1,121 10,43 78,47 1292,8 36 2626 2493 53,9 1228,5 -4.233 19,68
2461 83,91 1,151 12,61 83,87 1315,2 36 2642 2632 50,5 1307,6 -4,386 18,77
2774 91,96 1,222 13,55 91,64 1325,9 36,3 2687 2641 41,4 1345 -6,789 17,26
3071 96,77 1,262 15,26 96,17 1282,2 36,8 2622 2641 36,03 1476,9 -7,994 15,86
3363 97,44 1,243 17,86 97,37 1270,8 37,6 2603 2642 32,66 1646,1 -7,221 15,61
3648 98,23 1,219 19,66 98,18 1245,4 38,6 2568 2642 27,8 1652,7 -7,021 15,18
3932 98,54 1,225 21,21 98,37 1231,5 39,8 2571 2641 27,15 1641,7 -7,690 14,96
4172 98,84 1,227 22,85 98,79 1233,8 41,2 2613 2642 28,18 1648,3 -7,864 14,94
4403 98,92 1,227 25,4 98,71 1199,8 42,8 2619 2623 28,56 1654,9 -7,015 14,5
New mod, increase RAIL pressure to 1650bar, SOI is too late,boost are low and i know that duration are too long (+- 50us), car have smoke after 3000rpm (afr 15, i will have 17 with more boost)
how i can calculate EOI correctly?
I have not increased turbo pressure because I do not know how to calculate EOI correctly, I am afraid that SOI is very early, I have deliberately delayed it,
thanks in advance
JTD 8v Stage1+
Here my calcs very similar to yours, so your AFR/EOI from theory is ok. Real EOI is dificult to know without professional utils. You can finetune durations (I prefer to calc short that long here because EGT, smoke etc).
Beautiful to see Unijet pump doing 1650 bar and 98 mm3. Anyway it seems high quantity, I would go from 96 to 90 mm3 now.
Votre réalisation est excellente .
:thumbu p::thumbu p::thumbu p::clap::clap:
J adore .
Si seulement je pouvais faire pareil .
Cordialement
Discussion Starter #15
thanks ceecao for the file,
new updates, I broke the clutch, I did not slip, I had a smf with clutch of gta, I think the springs were broken, I did not skate, I directly broke, I left the cut at 4750 rpm similar to a gasoline I do not know if it was good idea (the springs surely suffered)
If someone is thinking of fitting a large turbo that is fixed on whether it is possible to remove that nut from the gearbox, next week after removing the gearbox, I will turn the turbo compressor so that it runs perpendicular to the radiator, above the turbo lung as have done in this post
ALFA 156 SW 1.9 16v TUNING by BERTOL
Thanks for the cheering
regards
Discussion Starter #16
photos of the broken clutch (99mm3 IQ)and the new dual-mass flywheel, on the left it looks like the turbo with the turbine rotated frees a lot of space, better access to the return of lubrication, we hope that endurance,
regards
It has been a pleasure to lend a hand in the regulation of the vnt, to adjust SOI / EOI well for those 100 mm3 and above all to remove some limitations that you had in some maps. Now to enjoy that car that will be around 260cv comparing it with what you and I know.
Greetings.
Only why other people in spain installed such cooler or was the temperature really a restriction?
I never had problems with the fuel temperature.
1 - 20 of 31 Posts
