took the old sud out for a run to get some heat to to the old girl and was messing about with the idle speed. with it running a bit quicker like about 1000 rpm it seams to have solved the gear problem as it seems to slot in to first much easyer! Could it of been because the engine was running very low on tickover that it was hard to select? or could it be because i have used a bolt insteadof a roll pin on the selector? any help would be good, thanks
