Is that starting from stone cold..?
Have you checked the glow plugs
Sounds like its not on all 4 and has a knock so maybe an injector faulty or even down on compression, what are the correction values read from fiat scan.
And you shouldnt rev an engine straight after its started and also not switch a turbo engine off just after its been reved
No from stone cold or hot its the same, I don't have access to ECU scan as i need a new obd cable so couldn't tell you yet, when it's going its not down on power, sometimes the problem is intermittent.
