Hello to all,
The lever command of the lights of my 147 started to working badly (I don't know the exact name in English).
When I flash to the right side, they start to flash and then stop (to continue I have to tap the lever), and now it only flashes when I hold the lever until it holds itself up (formerly it was enough to raise the lever up to the top spot), and sometimes the light of the instrument cluster goes off and I have to tap the lever to make it come back .
I know that this can only be solved with a new module of levers, which in AR is very expensive.
So I ask if anyone has had this problem and, if so , what did you do? Did you repair the part or bought a used one?
In case of purchase, is it the installation plug and play , or after the installation there will be conflicts with the can-bus, or the total km will start flashing , etc.
Is that the Eper , after insert the VIN, shows several references for this part...How can I know the right one for my car?
Greetings and thanks for the help .
