Hello, I have problem With low temperature on my 1999 156 V6. It never gets over 50-60 Degrees. I have changed the Thermostat Product No.: TH657187, but it is the same. I have also tried ac on and off, the same, never over 50-60
The fan turns on and off, and the temperature is Perfect inside the car, even in -10C and +10c, so I belive the actuall temp. is ok. Could it be the themperature gauge or something else?
BR
Ole
It's more likely to be the sensor than the gauge.
It's an easy fix.. and the sensor isn't tooooo shocking (£20~£30?) but obviously test it before you buys a new one. I think you can earth the leads and the gauge should go to "Max" but have a search on the forum. I'm sure someone described it better than me.. :D
Ralf S.
