Hope someone can help with this problem.
When i turn the ignition key to start the engine normally the yellow key in the display should go out and the engine should start. Now i am no expert but think this is the imobiliser.
This has not been happening. It can start first time or take 20/30 attempts to start. What i noticed is that the key symbol stays on and the engine does not start. Since Wednesday i have been unable to start the car.
I have changed the batteries in the key fobs (both).
Has anyone got any good ideas or advice to get me going?
Thank you.
Could be something as simple as a bad earth. There's a thick cable at tront of gearbox beneath air intake hose. Clean with wire brush to remove any rust and dirt and make a clean contact. If not that it could be immobiliser or ECU. Neither cheap fixes!!
This thread helped me with the exact same problem about 4 days ago.
Just needed to unplug and plug back in the wireless cable that starts from around the ignition key.
Worked perfectly after that.
Yes thanks. Did as you suggested, started first turn of the key.
Yes i will still be looking at the key symbol and praying!
Regards.
