I have problem with the AC blower of my 155 1.8 16V, when I on the ignition swithch the blower ON automatically and there's no display on bloweer speed selector and Aircon temp. display and both switches are not functionable. Anyone have same problem before that can help me?
Hi Abdul
As short wile back this topic was up and it seems that a voltage regulator bihind the clovebox can play up. My blower was sometimes not working so I thought better have a look. I found that my lead to the blower engine had fallen out - due to a cell-phone box for hand-free operation had been stapped to the lead and thus made the connector work loose. But the regulator is a Fiat Tipo item and cheap to replace.
Alfisti regards
Erik
HI,
thanks Bob?Eric, I still having the problem, I have Chnage the regelator its dosen't work.
Bob, my Aircon also not working, are you from Klang? do you know any good wireman around. I suspect some wwiring problem.
rahman ,try going to koolare in subang usj there will be able to rectify things for you but ask him for a guarantee for 6 months ,so you won't come back in a month or two , his ******** will come but negotiate a price first before repairs. or else get slaughtered.
rahman,
i'm from bkt. antarabangsa and i had a similar problem like yours a while back. i sent it to jool aircond in jln. kuchai lama and got it fixed.
the problem is the motor and it needs to be replaced. i had mine changed with a bosch motor (slight modification needed as the size is not the same). cost me rm450 for the job. and the aircond is working fine ever since.
go check it out. :rolleyes:
Discussion Starter · #7 ·
Hey Guys, I'm from Taman Tun and I'm a newbie too...My alfa's air con was like soft blowing gentle breeze when i got it and i thougt it was a climate control thing...but then i found that the blower was not blowing hard enough...anyway i hadn't check it out at the specialist yet...probably they will tell me to change it...
question is...is the air con gives out in your face air gushing blow or you tell me how it was supposed to blow.... need a comparison test before i get a blowjob
:rolleyes: :p :eek:
