Β·
Hi guys,
I apologize for starting a new thread, but I'm desperate and need to sort this out πππ
Sunday I changed oil, filters and spark plugs...
Anyway replaced everything and decided to do the ECU reset procedure of the Self learned Parameters with the MES. After that everything was reset to zero (fuel trims, throttle body learning parameters, ect).
The car runs great and feels strong already from 1500 rpm, even the N mode feels way much quicker, but the car has developed a problem!!! Occasionally the engine has problems catching the idle and it it will fluctuate between 500-1000 rpm. This happens only in neutral... The throttle response is very good though.
Did I do anything wrong during the process of self learning parameters time???
I did the reset and started driving the car almost immediately after the reset. Maybe I should have let her idle for some time before driving. According to MultiEcuScan there is a value from 0-7 for the throttle body learning parameters, where the 7 means the self learning was successful, but to me it shows a value of 11.
Can anyone confirm that you must let her idle before you start moving?Should I try to reset the ECU one more time? This is getting frustrating as at stops and go wen she behaves erratic!
Please help π
Please help π
