1 - 20 of 22 Posts
Hi all,
My Alfa 156 1.6 is up for MOT end of May and was wandering if there was any preprep I could do to help it pass and reduce the Mechanic bill!
Something like a bullet point check list would be ideal.:thumbs:
I do suspect there is a problem with Lambda sensor as I have the yellow engine dashboard light (which is either the key or lambda). My sidelights also do not work at the moment.
Discussion Starter #2
Also, my seatbelt often gets jammed but is rather annoying that anything else, I assume this isn't part of the MOT though.
ok
Just hope they come out and back correctly during the test.
fix sidelights
check ALL other lights
check clutch & brake pedal rubbers
driver window should be able to go down/up
airbag system needs to be operational
is ABS?
airbags are not part of the UK MOT test.
i did realise it was a UK MOT question, just pointing out issue that tend to cause failure in IRISH NCT & assumed it transfer pretty well :cheese:
So do you also replace the airbags when they reach their expiry date???
not that i'm aware of, the 10 year is recommended, afaik they are good for 15 years
do you?
do you?
Obviously we don't replace them over here.
But if you are checking airbags and the sticker on the door says they have expired (a 156, GTV, etc will say 10-years), how can they possibly pass?
no idea, i don't invent the ruels for NCT
D
Check all lights, check tyre depth is legal. Check whether handbrake is holding properly on a hill - not an exact test I know but .....
Oh and clean your car or at least dont take it in full of rubbish, shouldnt make any difference to test but I've always wondered whether making a good first impression helps
ABS and airbag lights are both checked. Testers have a list of what sequence the light should follow. If it doesn't do what it should do, that SHOULD be a fail. David is right in saying the ABS isn't tested, but the light must do what it's meant to do. To the best of my knowledge, if the airbag light is on, that's a fail too.
1 - 20 of 22 Posts
