Pre owner cut radio wires(help is here!!)
Ok the previous owner of my 156 cut the wires to the stereo when i bought and left me with no clue how to rewire it to my radio,
But with some very helpful suggestions from you at AO i hooked it back up, no more going to work in silence!!! And country road driving with alfa speed, steering, and good music, NICE!!
I had to go to a junk yard and cut off the connections and take them home, so to save you the hassle try this.
You should have an iso connecter thats labelled buy one in a motor facters 5 quid should do it.
My car is an alfa 156 98' 2.0l so i can only say i works for this model.
Anyway here it is youll need:
1. a multimeter
2. an iso radio connecter (plus radio)
3. Some basic tools ie. snips,phase tester........
Firstly there shold be two RED wires and 1 black, find them.
OK now get your multimeter set it to the 2nd lowest voltage it will go and direct current,
should be 20V.
ok now place the black cord (multimeter) against the black wire,
and the red cord against both red wires seperatly and record the voltage.
1 red wire should be lower in voltage than the other red wire thats the IGNITION/SWITCHED
2nd red wire should be higher in voltage thats the BATTERY/CONSTANT
Black wire is GROUND/CHASSIS
RED/GREEN = ANTENNA POWER
YELLOW/BLACK = DASH ILLUMINATION
BLUE/BLACK = FRONT LEFT +
GRAY = FRONT LEFT -
ORANGE =FRONT RIGHT +
WHITE/BLACK = FRONT RIGHT -
BLUE/YELLOW = REAR LEFT +
BLUE/ WHITE = REAR LEFT -
WHITE/RED =REAR RIGHT +
BLUE/RED = REAR RIGHT -
OK there should be 2 wires left over. do not hook them up to anything.
i dont know what their for so dont do it.
hope this saves a lot of painstaking searching that it cost me.
Good luck!!!!!!!!
