Assuming the power steering was correct before I replaced my engine, I don`t seem to be able to get it working properly,it whines and groans as if its not bled properly I have turned it left to right and still feels lumpy topped level of fluid correctly and doesn`t feel happy , any tips out there using Dexron 11 which is correct according to manuel , bottle says automatic transmission fluid dexron 11.
After a bit of searching in the workshop CD , I have found out that when you initially fill up the reservoir after a removal,you turn the steering from left to right without the engine running then drop the car to the ground , well gently lower, and turn on engine and turn steering again from l-r 5times and that should be it bled!
I wander if this is why I have so much air in the system and will not settle to quietness and normality?
