they are alloy but have a coating of rubber/plastic on themPlastic or alloy?
Good luck :thumbs:Yeah, a leak from the pipes connected to the reservoir - been quoted £30 from a breakers with a guarantee - I'll let you know how it goes
If it is just a coating, it must be really thick, because they sound like plastic. Definitely not rubber, they are plastic on the outside. A dealer told me that the alloy ones were replaced by plastic as the alloy rubbed through the connector to the hoses and plastic is softer/not so sharp. They feel like all plastic, but I might be wrong.they are alloy but have a coating of rubber/plastic on them
just seen the pic of the replacement pipe, mine was in a different place, the two sections that run under the rad, it went 1st on the passenger side, patched it up until i could get a replacement then on the drivers side both times less than an inch from the bracketsWas your leak from the same place as the OP's? - just interested as mine holed near oine of the brackets
it could well be plastic, mine was a different pipe (under rad)If it is just a coating, it must be really thick, because they sound like plastic.
