1 - 20 of 24 Posts
Hi All,
So my 156 which decided to break down on every test drive has been diagnosed with a 'possible' overheating ECU:
After driving the car for a while it would flash false alarms and cut out. Refusing to start.
*after this the engine light flashes rapidly and a fast clicking is heard from the engine - throttle body?
An ECU reset clears the fault but it returns after a while...
Is it easy to replace the ECU and key chips?
ECU can be had for sub £200 with 2 key chips... +2 hours work from me (I'm a novice)
**OR, A mate needs a temporary car: a workmate had the exact same problem with a french motor, but had this novel fix: route an air pipe from the grill to the ECU with a PC fan attached to the ECU side! his car has run fine since!!!
which is the best option? has anyone had similar and tried the air cooler fix for the ECU?
We can do you an ecu thats plug and play to your own code box,(just direct replacement,5 minutes)
Give us a call ,if interested:)
You say the codes have been reset, what were the fault codes to be exact?
It smacks of a typical crank position sensor failure to me which would definitely explain the failure to start when hot.
Do a forum search for full description and comprehensive repair procedures of crank position sensor issues... You will soon see comparisons.;)
I have never ever come across such a case of an overheating ECU before????:rolleyes:
but if that is what it needs after all avenues of fault finding have been exhausted, then Alfatuner is your guy.;)
Discussion Starter · #8 ·
thanks guys,
*I can't get the codes, I've tried 2 dongles and laptop and my phone, I can't connect to the car at all :( I should just try again after another reset perhaps... when the ECU thinks its fine again? I didn't want to lose the codes so I've not reset the ECU this time
I did a couple old threads many months ago when the car first broke down, a new battery might have fried the ECU when cranking the car too long to get it started... NOT me! the mechanic told me I wasn't letting it crank long enough, lo and behold it did start after he cranked it for a short while longer in succession than me.
'overheating' ECU, I maybe have labelled this wrong, it only cuts out after a while of driving and 3 alfa indies have stated 'AH THAT'S THE ECU!' when I describe the problem, the smoking gun being: the engine light and electrical clicking from the engine bay while the dash lights are on - key position before ignition.
So how hard is an ECU swap? and the chips in keyfobs too? looks like bolts and the connectors?
can I just borrow this thread for a second and ask this:
I have a AR147 with faulty body ecu (not engine ecu). If I replace my body ecu with one from same car (same model, type, engine, gear) will my car start, or do I need to do some kind of reprogramming for body ecu?
Thanks a lot for the information!
Discussion Starter · #10 ·
Chaps, having read a few crank shaft threads and it doesn't sound like it's this; as I have the engine light blinking and the rapid clicking noise from the engine - This is before I try to crank the engine, this is when the dash lights up during the usual system check. and random faults may appear on the infoscreen.
If I try to crank her she just doesn't start - that could be down to anything not feeding info to the ECU!
It sounds like I have 2 things to ponder:
1- ECU replacement...
2-Bad earth to the ECU? - although how could that clear with an ECU reset?
^mr tej, zdravo, sorry I have no clue but if you are lucky someone will set you straight soon
To me the rapid clicking sounds like the starter solenoid - a classic symptom of a flat batter (or a poor connection somewhere)
Discussion Starter · #12 ·
I am having trouble locating it without proper diagnostic tools! I am not at home for a start :)
No multimeter and was unable to connect to the ECU...
it was kind of coming from the middle/back of the engine block, I just can't tell, if the ECU reset fixes it for a time it can't be a dodgy connection, has to be an actual part that is failing, thus tripping out the engine after a while of running.
More head scratching or stumping cash to have someone actually pop over to check it!
anyone up for a visit to west london? worth a couple of pints or a curry!
I don't know what ecu you mean. Engine, abs or airbag. What's a "body" ecu?
listen to Alfa Tuner ! he knows his stuff !!!
The 147 has a separate ECU which controls most of the functions of the car other than the airbags and the engine. Its known as a body computer.
Does that negate the use of relays for those functions?
I suppose it's because of the can bus?
1 - 20 of 24 Posts
