I replaced my Oxy Sensor and spark plugs yesterday and reset the fault code.
This morning I plugged my car into my laptop and noticed P0130 Lambda sensor fault again. I reset the fault code and started the motor. I set FES to graph the voltage on the sensor and after about a minute of running the voltage began to rise and fall which is correct, from what I read.
Here is a video of the readings: MobileMe Gallery
Is there anything else that could give that error code? Should I do the full ECU reset and get it to learn the settings again?
