Has anybody used the poly mounting inserts sold by eb spares. I find my spider gearstick moves a fair bit on acceleration and deceleration and presumably these would stop this. I've had a quick look underneath and the mounting doesn't look obviously worn. Would stiffening up the gearbox support have any adverse effect, i.e. judder or increased noise transmission
Have you checked the engine mounts , these are much more likely to be worn the the gbox mounts and will allow a fair bit of movement, the last thing you want to do is transmit more engine vibration to the body by fitting harder mounts , it will just be unpleasant
the S4 transmission mount is a soft design by nature.
Poly is not the way to go here.
Like Joe, I suspect engine mounts....try and snap a photo of both sides. If you see any slight balooning of the rubber, they are on the way out.
If you need to replace them, then replace all 3 together, engine and tranny with OE mounts.
yeah, first thing I checked was the engine mounts, like the gearbox one look ok visually. I'll leave well alone for the time being.
check for mounts that I go by (if not obviously squished when looking at them) is:
1. look under the car, sump must be horizontal/level to the ground (even though top of engine is canted)
2. space between front crank pulley and swaybar.....on good mounts you should just about get a finger between there.......not just a feeler gauge!;)
