After many failed attempt to fix my selespeed, I decided to buy another used one with its ecu... Is a 2003 selespeed gearbox different in any way compared to my 2001( connections/ports etc...)
Don't think there will be any differences - and it will probably work with your existing ECU - unless that is the problem, in which case just changing the ECU would probably sort it....
There was a change to the actuator shaft in the gearbox with actuator changed to match.
So you either need a gearbox to match your existing actuator or a gearbox that comes with its actuator.
Don't think there is a clear cut date when the change happened with possibly both being used at the same time...
I got the whole gearbox and it's ecu and wiring loom so guess I'm good to go
