a few months ago my gearbox dumped its oil the garage i took it to thought it was the first motion seal but when the box was dropped there was a crack/small hole in the gear box the gearbox still works cause i drove it to the garage what im wondering what could of caused this crack/small hole
many thanks in advance
A friend put his Civic into a ditch once... that left some nice cracking patterns accross the base of the gearbox and he sold it a while later... :rolleyes:
Big rock? Speed bump?
well the way the problem happened was i had a car pull out on me had to do an emergency stop but would of not stopped in time so i shift down from 4th to second then when i tried to pull away the car didnt feel right got out to check and that when i notice the oil
also the whole is where the clutch goes not the out side if you get what i mean
no no no its where the clutch would sit mechanic said it looks like something tried to punch its way through
Perhaps the clutch is nearing the end of its life (heavy? slipping? biting point high?) and has lost a spring finger, which had popped off during a quick stomp on the pedal. I know it sounds far-fetched but in some clutches I have seen the release bearing wear the ends of the fingers so much that the bearing housing scores a line around the fingers, creating a weak spot where tye finger then snaps off.
Then again I guess you have the gearbox off and are getting the casing welded, so you'll have inspected the clutch by now.
-Alex
you would think the guy would weld it but no he used what he called a metal cement glue and said that he didnt know how long it would last and that it should only be a temp fix and as this has cost me £470 i cant afford a second hand box
