Hi All,
sorry to post this again but im just not having any joy at all!
Central locking does not work at all with key or fob!!
nothing at all happens, nothing locks and the alarm does not arm.
the controll box (multifunction ecu thing!!) just clicks when i lock the doors and i have replaced the control unit under the glove box but its the same.
Any suggestions? can anyone tell me where the relays are? I have checked the fuses one by one and all are intact.
does anyone have a fuse - relay layout?? the car is a 2000 1.8 ts!
V
did the key work when you first got the car or has it not worked scince you've had it.
sounds like the key is not programmed for the car. a dealer will be able to reprogramme it for you (you need codes from italy iirc)
when i click the fob or lock with the key, the window and CL ecu (multifunction unit) clicks. does this suggest that its receiving the signal?
would the car start if they key was not coded? ansd yes i have had the key since i had the car but the CL has never worked.
what and where is the body computer...sorry im fairly slow!!!
thanks so far guys
