1 - 20 of 20 Posts
I have just bought a HID kit the one everyone recommends. All fitted but tried to test it and now no lights (all work apart from dipped beam) and now engine management light and she will not start.. Turning over but not firing. Code lights out etc.
Chris, check some basics first:
Are the HIDs wired in the right way round? Have you blown a fuse?
Why it isn't starting is more of a mystery, did you unplug the battery while changing the lights?
Check the polarity on the lights (I had this problem too).
Also check battery conections, battery power, and fuses.
In reality I cant see anyway plugging some HIDS in will cause an engine management lights and a failure to start - unless they are cheap crap and have put a power spike through the ECU?
Much more likely that you have the polarity wrong and have run the battery low whilst playing around.
Not sure how true this is but I was told (don't laff :tut:) that you can't put HIDs in the spiders :rolleyes::confused:
Complete rubbish.
Had them in mine for coming up 2yrs with zero problems.
Best upgrade you can do IMO.
Complete rubbish.
I'd really like to change them on both the TS and the V6.........in words of one syllable....HELP?? Where should I lookfor some? :thumbs:
I think it was a young boy in Halfords actually ....serves me right :lol:
Theres a huge thread on the 1st page of this 916 Forum.
Thanks guys... Hid now working... Plugged in the wrong way... :{.... Now just trying to reset it by disconnecting the battery... Fingers crossed this works....
Hehe, told ya
yeah i think ( althought its now a very long thread) its covered in the thread about reversing the conections
exactly as i had to do
She won't start :(...
No code lights just the engine management light on... Turning over quickly but just not catching...
Try resetting the fuel cut off as well. Passenger side footwell. Failing all of that disconnect the battery and leave it for 30mins to reset the ECU.
As you were doing things with the plastic wing cover removed ( presumably ) I'd check the relays and fuses close to the driver's side headlamp. About midway(?) between the headlamp and the strut. Lots of relevant relays there for the engine ECU, fuel pump, lambda ...
Something could have been dislodged.
Discussion Starter #17
Sorted it!!!! Relay on the fuel pump had gone... All replaced and back running... So cold torch light at just gone 11pm!!! Don't you love just having one as a daily driver!!!
1 - 20 of 20 Posts
