1 - 20 of 27 Posts
Hi guys, I need to change my rear disks and pads and just found out the hard way after hrs messin around with the damn things that i need a specific tool. The piston rewind tool. Has anybody got one to lend or assist me with in and around Leicester?
:rolleyes: Why couldn't it be easy like the fronts.
(I'll be offline tonight, out and about but will check 2mrw morning:) )
*Edit- Thanks for all the advice, brought one from Halfords for £21.
I know i will get stick for this, but......you can CAREFULLY use a STRONG pair of long nose pliers and a strong arm to do this with ease...
there, now i will get grief about bodging up the caliper :rolleyes: :D :D :D
K
That's what I do too. It's hard going if the piston is seized but otherwise, it'll be fine.
Get to Halfords and buy the Laser caliper rewind tool. Then after you have finished, clean it up a bit and take it back for a refund.
Thats what someone has done to the one i just bought! Packaging was perfect, but a couple of staples missing and oil on the steel plate and bit that fits in the piston!
:confused:
Allan
i have used a large g clamp and some pipe pliers, keep some pressure and turn, obviously. sometimes its the kind of thing that people have in their garage anyway.
I have a laser wind back tool. It was one of the best investments I have made. :thumbs:
I bought the same tool Symonh... Strange though, it was for my old Citreon C5 front calipers, yet fits perfectly on the Alfa 156 rear calipers too!!!
I agree, worth while investment. It saved me screwing up the citroen's brakes as the piston wind back threads are specifically "handed" per side:thumbs:
Use a G clamp put the moving end into the piston and help the piston around with pliers for the first turn and then it should go back with just the clamp :thumbs:
Worked for me :)
Worked for me :)
Really? So no rotating after the first turn??
look at the Laser tool site ! there is the perfect tool
1 - 20 of 27 Posts
