1 - 14 of 14 Posts
Hi all,
So, I have bought this unit to fit into my Gt...
And it looks like this (bezel arrives tomorrow)
However, I attached the iso to the alfa loom and there's no power.
I think the pinouts need changing but am stuck.
With the following pics, could someone advise which pins need to go where?
Original stereo diagram
Pioneer loom (power end)
Pioneer loom description (vague)
Sent from my E6653 using Tapatalk
you have to swap yellow and red cables on pioneer harness ie red to yellow otherwise every time you start the car the headunit will go on set up mode and then you have to bring a wire from sig lighter(middle wire on white connector) and connect to yellow cable (which in turn is swapped to red one),
then to get speakers working you will have to connect bose cable from green small connector(if memory serves right) to white/blue cable on pioneer harness,that blue/white wire is marked as remote control or something like that i do not remember,you will see it easily it's not connected to anything
i put pioneer last week in my GT and still waiting for fascia panel :thumbup:
Great stuff, didn't realise there wasn't an ignition feed on the existing stereo loom. I've added a length of wire to the red wire of the pioneer loom which is going to the cig lighter and the yellow wire has been plugged into the red plug at the end.
As I'm not running a bose system, speakers should be fine as they are?
Well had a quick read up and you're right, red and yellow swap over and you take ignition feed from the cig lighter. Now works fine.
Thanks for the help folks :)
You might want to check the current drain once fitted. Switch car off; wait a couple of minutes and check current drain from battery. First leaving unit on and switching car off and second switch unit off first and then switch car off. Some of these units pull almost half an amp in "standby" and will slowly flatten battery if left for a week or so or if you only do short journeys.
Not all. Some do and some don't.
Thanks for the tip :)
To be fair I do about 250 miles a week so I doubt it'd run flat, but you never know
I fitted an alpine head unit and changed the front speakers to alpine ....but still no bass
So i had to fit a subwoofer with built in amp and put it in the boot. Now i have bass.
Nice headunit but the standard speakers are totally naff.
Sent from my iPad using Tapatalk
I'm wondering if my speakers have been changed by the previous owner then as I'm not finding the quality that bad?
1 - 14 of 14 Posts
