No, just the grinding.
The balancing was done by a chap in Huddersfield.
would you recommend him ?
Also - did you tap the crank oil ways to take the grub screws and does it really take a coiple of hours each ? Sorry about all the questions i'm just about to start a build.
No problem with the questions!
Yes the guy in Huddersfield was great. I'll PM you his number as he seems very private and doesn't like advertising!
Tapping the crank wasn't as bad as I expected but the 1750 crank isn't nitrided like the later ones so that might have helped. It was still a steady job though! I went for an M8 size thread and got a brand new set of three taps and also a ratchet T wrench as you are working quite close to the crank so there's not much room in there. Got everything from Bradford Bolt & Nut. I think the grub screws were 12mm long.
The old alloy plugs just drill out. Start with something like a 5mm drill and you will probably find they just spin out once the drill bites. You need loads of pipe cleaners too. It's a steady job!!
:D
