went to move the gtv from my dads garage to my bodyshop last night and the damn thing wouldnt start!
cars been sat a while (about 8 months at a guess)
fitted a new battery, car turns over but wont fire,
Key Code light goes out, injector light doesnt (it comes on with ignition, after about 8 seconds (fuel pump still priming) the injector light goes out for a split second then back on) and stays on, the car cranks
i can hear the fuel pump priming, ive taken the 3 red relays out from behind the osf head light cover off and cleaned and reinstalled (and swapped them all around) still no joy
ive checked all the fuses
i removed a spark plug and it was bone dry, so no fuel coming out of the injectors??
anybody have any ideas??
the engine was fully rebuilt by jamie porter @ thealfaworkshop about 18k miles ago, everything replaced.... base liner seals, head gaskets, timing belt, and just about everything else! (to the tune of £2500)
i dont have access to any diagnostic equipment (the cars at my workshop in lingfield (RH7 6DF) if anyone local has it and fancies helping out.... :thumbs:
my first thought is, cam position sensor? or maybe crank pos sensor? im guessing the injectors are not getting the pulse signal to fire the injectors?
