Hi
The passenger window stopped working last week, in the UP position thank god. The Driver's still works. I took the door card off after checking the two white 25amp fuses were fine and swapped the switch from drivers to passenger door with no affect. I used voltage tester (test light)to check if I had power at the switch and nothing. Nothing at the motor either? I pulled the door loom plug off and made sure the connections are OK and corrosion free and they are.
Any thought where to go next?
