I notice that I have excess wind noise around the doors.
The rubber strip going down rear edges of doors on the bodywork keeps popping off its buttons and also at the junction where the top of the door touches the door shut line there is a fairly tight zigzag that the rubber goes and this keeps popping off.
Is this common, am I best just replacing or is there a fix?
cheers steve
If you slide off the rubber seals (upwards) you just need to replace the plastic channels underneath that clip onto the body work. I did mine a few months back, cheap as chips from alfa.
I gave my door seals a good clean and then a good soaking in silicon lube and they came up like new.
All the best
MC
I put a thin layer of the black sticky foam that came with my Infinity speakers (like draught excluder) inbetween the rubber parts of the window seal . It padded it out by about 4mm, is vertuely un-noticable and made a huge difference, although not totaly cut out the wind noise.
