1 - 18 of 18 Posts
Hi, I'm new to the forum! I personally own an Alfa Romeo 156 1.6ts, soon going to swap it with a 2.0ts. Do anyone knows from where I can get pdf manuals for this kind of cars? All I could find is this : .:BerlinaSportivo - Alfa Romeo 155 Q4 and Sports Saloons on the net:. . All the files are ISO and...I belive they need to be burned on a disk or something? And since I don't have a dvd rom to my PC anymore (because we live in 2020 after all) maybe someone can get em' to work?
Download a virtual disc tool such as Daemon Tools and mount the ISO file in that, it works the same as an actual DVD and you will be able to view the files contained in the ISO.
Hmmm, interested, I'm working on it rn with a friend
Few days ago I spent a full afternoon trying to get rid of the CD dependency, and finally got it done.
Also I modified the elearn executable, so every elearn uses its own folder path, which means you can have multiple eLearn installed and opened at the same time.
Stay tuned, I have to modify and upload them all, but won't take too long;)
It's almost done, files are uploading. Check this link.
I will make a proper thread later.
This is a first release test, but should work pretty well.
Just download, extract, --read the instructions-- and run the included installation file.
Lots of hours of reverse engineering, process spying and FAILS, sadly I'm not a experienced hacker 😂
Any chance of a MiTo elearn?
thanks in advance
Newer alfas have keyElearn, it's an online paid service, so no, sadly there're no more elearn manuals.
I wondered when they would stop that .. I think I have a Punto Grande version somewhere which is close enough for most things .. :)
Hi, thank you so much for all the work you done!
Discussion Starter #11 (Edited)
tho, I have a question. After installing the setup, what should I do? The eLearn thing won't work, since it says that it misses a file. Edit : I figured it out but now the problem is that it asks for some kind of CD.
937176
Administrator
GT 2.0 JTS
I tried this myself, loaded all files but could not even get the Elearn page to load.
Are you running the .bat file? What elearn? What OS?
Tell me so I can try to figure out the problem!
Edit:
Now suddely happens here too! But only with older ones (147/156/166/gt).
159 & brera elearn run fine. Then I found something. After opening the 159 once the rest started started to work!
So there might be something that the 159 elearn does to the system.
Download the 159 eLearn and try with it. If it works, then open the other one.
Edit2:
Tried modifying the 159 exe for 147/156/166/gt and it seems to work nicely! Try and report...
Remove the txt extension!
Administrator
GT 2.0 JTS
I tried but I got a Trojan:Win32/Azden.A!cl warning! which stop it loading.
WTF? Really? Only 4 bytes are changed in the file, download the 159 eLearn and compare yourself:ROFLMAO:
Clearly 2 false positives for...whatever... lol.
Maybe it's the fact that it's a Zip file with txt extension, that triggers some heuristic algorithm (this is not a text file, uhmm...)
937256
Discussion Starter #17
By downloading the 159 file, will I have the access to the 156 manual as well?
1 - 18 of 18 Posts
